The curve to curve constraint consists of a 3D curve fixed on one body rolling and
sliding on a 3D curve fixed on a second body. The curves are required to have a unique point
of contact and a common tangent at that point of contact. The curve-to-curve constraint is
useful for modeling cams where the point of contact between two parts changes during the
motion of the system. The curves always maintain contact, however, even when the physics of
the model might dictate that one curve lift off the other.
If the Advanced Joint panel is not currently displayed, select the desired
advanced joint by clicking on it in the Model Browser or in
the modeling window.
The Advanced Joint panel is automatically displayed.
From the Connectivity tab, click the Curve 1 collector
and select the curve that belongs to Body 1 from the modeling window, or double-click Curve
1 to open the Model Tree (from which the
desired curve can be selected).
In the same way, pick the curve for Curve 2 that belongs to Body 2.
Click the Ref Marker 1 collector and select the
reference marker that belongs to Body 1 from the modeling window, or double-click Ref Marker
desired marker can be selected).
In the same way, pick the reference marker for Ref Marker 2 that belongs to
Body 2.
The fields of Body 1 and Body 2 will automatically populate with the
appropriate body labels.
Click the Initial Conditions tab.
Select the User Initial Condition
Marker check box and select the desired marker using the Marker
collector.
By default, this marker is the curve reference marker that belongs to Body 1
and Body 2 respectively.
Select the Use XYZ check boxes and
enter the initial position values into the X, Y, and Z fields to specify the two
contact points.
Note: If user-defined contact points are not provided, MotionView will measure the distance between all the
points on the curves and pick two points (one for each curve) that are close
to each other.
Select the Use velocity check
boxes and enter in values to set the initial contact velocities for Curve 1 and
Curve 2.
This velocity is as measured by an observer located at Ref Markers of each
curve.
Tip: If the values for the initial contact point and
initial contact velocity are known for the CVCV joint, then it is
recommended that they are specified while defining the joint.
