The surface to surface constraint consists of a surface on one body rolling and
sliding on the surface of a second body. Each of the surfaces are required to have a unique
contact point. The surface to surface joint constrains the two surfaces as follows: the
surfaces have exactly one contact point, and the normal at the contact point for each is
anti-parallel.
If the Advanced Joint panel is not currently displayed, select the desired
advanced joint by clicking on it in the Model Browser or in
the modeling window.
The Advanced Joint panel is automatically displayed.
From the Connectivity tab, click the Surface 1 collector
and select the surface that belongs to Body 1 from the modeling window, or double-click the collector to open the
Model Tree (from which the desired surface can be
selected).
Similarly, click the Surface 2 collector and select the
surface that belongs to Body 2 from the modeling window
or the Model Tree.
Click the Ref Marker 1 collector and select the
reference marker that belongs to Body 1.
In the same manner, click the Ref Marker 2 collector and
select the reference marker that belongs to Body 2.
The Body 1 and Body 2 fields are automatically populated with the
appropriate body labels.
Click the Initial Conditions tab.
Select the User Initial Condition
Marker check boxes and select the desired markers using the
Marker collectors.
The default initial condition markers for the surfaces are the reference
markers that are specified in the Connectivity tab.
Select the Use XYZ check boxes and
enter the initial position values into the X, Y, and Z fields to specify an
initial position for each surface.
Note: In the absence of user input, MotionView will
measure the distance between all the points on the surfaces and pick two
points, one on each surface, that are close to each other.
Tip: If the values for the initial contact point are known for the SFSF
joint, then it is recommended that they are specified while defining the
joint.
