A point to surface joint constrains a fixed point on a body to slide along a surface.
The point to surface joint provides five degrees of freedom: three rotational at the
instantaneous point of contact and two translational DOF.
If the Advanced Joint panel is not currently displayed, select the desired
advanced joint by clicking on it in the Model Browser or in
the modeling window.
The Advanced Joint panel is automatically displayed.
From the Connectivity tab, click Body
1 and pick a body from the modeling window, or double-click Body 1 to open the Model Tree (from which the desired body can be
selected).
Click the Point collector and select the point of the
PTSF joint from the modeling window (or pick the point
from the Model Tree).
Click the Surface collector and select the predefined
surface for the joint from the modeling window (or pick
the point from the Model Tree).
Click the Ref Marker collector and select the surface
reference marker that belongs to Body 2 from the modeling window or the Model Tree.
Click the Initial Conditions tab.
Select the User Initial Condition
Marker check box and select the desired marker using the Marker
collector.
The default initial condition marker for the joint is the reference marker
that is specified in the Connectivity tab.
Select the Use XYZ check box and
enter in the initial position values into the X, Y, and Z fields to specify an
initial position for the point.
Note: These values will supersede those specified by the Point collector in the
Connectivity tab.
Tip: If initial conditions are known, it is better to specify them while
defining the joint as this will help reduce chances of error in results. If the
initial conditions are not specified, MotionView will
calculate the point on the surface that is nearest to the point specified for the
joint in the Connectivity tab.
