DMIGMOD
Bulk Data Entry Defines changes in the contents of a super element from H3DDMIG input.
| DMIGMOD | MTXNAME | SHFGID | SHFSPID | SHFSPID_F | SHFCID | SHFEID | SHFRID | ||
| HYBDAMP | METHOD | SDAMP | KDAMP | METHOD_F | SDAMP_F | KDAMP_F | |||
| ORIGIN | A1 | A2 | A3 | ||||||
| GIDMAP | GID1 | GID1A | GID2 | GID2A | GID3 | GID3A | |||
| CIDMAP | CID1 | CID1A | CID2 | CID2A | CID3 | CID3A | |||
| RELOC | PA1 | PA2 | PA3 | PB1 | PB2 | PB3 | MIRROR | ||
| GRDTOL | ERREXT | TOLEXT | ERRINT | TOLINT |
| MTXNAME | Matrix name defined on
ASSIGN,H3DDMIG. No default (1 to 6 characters) |
| SHFGID | All Grid identification
numbers in the superelement are shifted by the specified value. If
this field is left blank, then a shift does not occur. 2 Default = blank (Integer or blank) |
| SHFSPID | All
SPOINT identification numbers in the
superelement are shifted by the specified value. If this field is
| SHFSPID_F | All Fluid
| SHFCID | All Coordinate System
identification numbers in the superelement are shifted by the
specified value. If this field is left blank, then a shift does not
| SHFEID | All Element identification
| SHFRID | All Rigid Element
| HYBDAMP | Keyword for the remaining data for superelement damping. | |
| METHOD | EIGRL card identification
number. Hybrid damping would be applied on the superelements for the
modes referred by EIGRL card. If blank, then
applied damping on all the modes. Default = blank (Integer > 0, or blank) |
| SDAMP | Identification number of
TABDMP1 entry for modal
damping. No default (Integer > 0) |
| KDAMP |
Default = 1 (Integer) |
| METHOD_F | EIGRL card identification number. Hybrid damping would be applied on the fluid part of superelement for the modes referred by the EIGRL card. If blank, then modal damping is applied damping to all the fluid modes. | |
| SDAMP_F | Identification number of
TABDMP1 entry for fluid modal damping of the
superelement. No default (Integer > 0) |
| KDAMP_F |
| ORIGIN | Keyword for defining the new ORIGIN for DMIG. | |
| A1, A2, A3 | Defines the new location
of the origin of the DMIG. Default = 0.0 (Real) |
| GIDMAP | Keyword for defining mapped grid ID pairs. | |
| GIDn, GIDnA | Mapped grid ID pairs. | |
| CIDMAP | Keyword for defining mapped coordinate system ID pairs. | |
| CIDn, CIDnA | Mapped coordinate system ID pairs. | |
| RELOC | Keyword indicating that matching grid point ID pairs in the residual structure and superelement are to follow. 1 | |
| PA1, PA2, PA3 | ID's of three non-collinear grid points in the residual structure. | |
| PB1, PB2, PB3 | ID's of three non-collinear grid points in the superelement that will be matched to corresponding grid points in the residual structure (defined by PA1, PA2 and PA3). | |
| MIRROR | Flag to indicate that a relocation operation is mirroring/reflecting. 4 | |
| GRDTOL | Indicates that the grid point tolerance settings between matching residual and superelement grids are to follow. | |
| ERREXT | Specifies whether OptiStruct will:
| TOLEXT | Tolerance value to compare
exterior grid locations. Default = 1.0e-15 |
| ERRINT | Specifies whether OptiStruct will:
| TOLINT | Tolerance value to compare
interior grid locations. Default = 1.0e-5 |
- The RELOC entry and its
related fields define three matching grid point pairs on the residual structure and
the superelement. The superelement defined using ASSIGN, H3DDMIG is relocated
(translated and rotated, as required) such that the three non-collinear grids
PB1, PB2, and PB3
coincide with PA1, PA2, and
PA3, respectively on the residual structure.
Figure 1. - Identification numbers of certain entities in a superelement can be modified during H3DDMIG input. Negative integers can be input in the shift fields on this entry (see fields beginning with 'SHF' above), however, care should be taken to ensure that the identification numbers are not shifted to negative values. The values of identification numbers after shifting should always be greater than zero, otherwise, the run will error out.
- The use-case of GIDMAP is to renumber the interface grids IDs such that they match with the IDs used in the residual structure. Also, renumbering interior grids IDs such that they do not conflict with exterior grids or with interior grids in another superelement. For the latter use-case, SHFGID will also be used to avoid the conflict. If both GIDMAP and SHFGID are used together for the same superelement, the renumbered grids with GIDMAP will not be renumbered again by SHFGID.
- When RELOC and
MIRROR are used, there are two ways of defining the reflection.
- Define PA1, PA2, and PA3 which identify the plane of reflection about which the entire superelement will be mirrored/reflected.
- Define PA1, PA2, and PA3 in the residual structure and PB1, PB2, and PB3 in the super element. In that case, the super element is mirrored/reflected after being relocated.
Note: Any rotation, translation or mirroring required to complete the mirroring process is accomplished internally by OptiStruct. These three grid points cannot be collinear.
