SENSOR
Bulk Data Entry Sensors may be used to activate loads.
| SENSOR | SID | STYPE |
| LSID | GID | LBOUND/LTID | UBOUND/UTID |
| SENSOR | 2 | TEMP | 4 | ||||||
| 4 | 933 | 100.0 | 200.0 |
| SID | Unique sensor
| STYPE | Sensor type.
No default |
| LSID | Load set identification
number of a QBDY1 or QVOL Bulk Data Entry. No default (Integer > 0) |
| GID | Grid or scalar point
| LBOUND/LTID | Lower bound of the
temperature range, or the table identification number of a
TABLEDi entry which specifies the lower bound
as a function of time. No default (Real or Integer) |
| UBOUND/UTID | Upper bound of the
TABLEDi entry which specifies the upper bound
- A SENSOR can only be activated once. Sensor with TYPE=TEMP is supported only for Transient (linear and nonlinear) Heat Transfer analysis.
- The presence of the SENSOR Bulk Data Entry with TYPE=TEMP turns off the referenced LSID loading outside the defined temperature range and turns on the LSID loading inside the temperature range (LBOUND/LTID to UBOUND/UTID).
