MESHF
Bulk Data Entry Defines options for user-defined input of frequency ranges used to define bands in adaptive meshing for acoustic Adaptive Perfectly Matched Layer (APML) analysis.
MESHF MFID FVAL F FRNG F1 F2
FRNG F1 F2 FVAL F
etc.
As shown in the example below, FVAL and FRNG do not need to be defined in any particular order. Five frequency bands are defined in this example: [10.0,10.0], [20.0,40.0], [41.0,41.0], [50.0,50.0], [51.0,80.0]
MESHF 7 FVAL 10.0 FRNG 20.0 40.0
FVAL 41.0 FVAL 50.0
FRNG 51.0 80.0
MFID Mesh frequency identification number. This can be referenced on the MFID field of PACPML Bulk Data.
No default (Integer > 0)
FVAL Flag indicating that a single frequency value (F) is to follow.
F Single frequency value to be a part of the frequency bands.
No default (Real)
FRNG Flag indicating that two frequency values (F1, F2) are to follow.
F1, F2 Two frequency values identifying a frequency range that defines a frequency band.
No default (Real)
  1. Any number of FVALs and FRNGs can be defined on this entry.
