TEMPD
Bulk Data Entry Defines a temperature value for all grid points of the structural model that have not been given a temperature on a TEMP entry.
| TEMPD | SID | T | SID | T | SID | T | SID | T |
| TEMPD | 1 | 216.3 |
| SID | LOAD
set identification. (Integer > 0) |
| T | Default temperature value.
From one to four default temperatures may be defined on a single
entry. (Real) |
- Temperature sets may be selected for use in a subcase by the TEMPERATURE(LOAD) or TEMPERATURE(BOTH) Subcase Information Entry. They can also be selected by the EXCITEID field of a TLOAD# entry or selected on the IC Subcase Information Entry. They can also be combined with other TEMP or TEMPD Bulk Data Entries on a TEMPADD Bulk Data Entry. For more information, refer to the TEMPERATURE Subcase Information Entry.
- This card is represented as a temperature load in HyperMesh.
