Create Event
Create an event consisting of channels and loadcases.
- In the Project Tree, open the Fatigue SN/EN Time Workbench.
                On the workbench toolbar, click
 (Create event).
             - In the window, pick the channel group that will be used to create an event.
                Create a channel-loadcase map.
- Click Add row.
 - Pick channel and structural loadcase to be mapped from the drop-down list.
 - Optional: Pick a channel scale and offset.
 - Optional: Apply event repeats.
 - Optional: Appy channel gate range.
                For SN random fatigue subcase:
- Select the random dynamic subcase from the drop-down menu.
                        Select the structural loadcase to define mean stress correction.
                        The default is None.
 - Set the exposure time.
                Click OK.
                The events appear in the Project Tree.
 - Optional:
                Right-click on the Events folder and select Export events to
                        CSV to create a .csv file from current
                    fatigue events.
                You can import this .csv to another project to quickly apply the same events.
