Import Sequences
Import a file to automatically create load case sequences.
- In the Project Tree, open the Fatigue SN/EN Time Workbench.
                On the workbench toolbar, click
 (Import loadcase-channel map).
             - In the dialog, specify the the multi-loadcase analysis to use to create load case sequences.
 - Click Import from CSV and navigate to the desired sequence file.
 - Click OK.
Imported Sequences File Format
CSV file format for importing sequences.
CSV file format fields
- Sequence name – Alpha-numeric values. Name of the Sequence.
 - Repeats – Numeric values. Sequence repeats.
 - Loadcases – Loadcases to define the sequence.
Example CSV file
Sequence name, Repeats, Loadcases
Sequence 1, 12000, 1-2;4-6
  Sequence 3, 8000, 1;3;5;1
