Create Sequence
Create a sequence with load cases for the fatigue analysis.
- In the Project Tree, open the Fatigue SN/EN Time Workbench.
                On the workbench toolbar, click
 (Create sequence).
                Create a sequence.
- Click Add row.
 - Pick the structural loadcase or multi-loadcase from the drop-down list.
 - Optional: Assign load scale.
 - Optional: Apply Sequence repeats.
 - Optional: To start the sequence from 0, select the Start from zero load check box.
                Click OK.
                The sequence will appear in the Project Tree.
 - Optional:
                Right-click on the Sequences folder and select Export sequences to
                        CSV to create a .csv file from current
                    fatigue sequences.
                You can import this .csv to another project to quickly apply the same sequences.
