SS-V: 5090 Bushing Stiffness
Test No. VNL10 Find the rotation of cylinder subjected to a moment of 10 N-m along its length.
Definition
- X
 - 100 N/m
 - Y
 - 100 N/m
 - Z
 - 100 N/m
 - Rot X
 - 10 N-m/rad
 - Rot Y
 - 10 N-m/rad
 - Rot Z
 - 10 N-m/rad
The units are SI.
Dimensions: D = 443.3 mm, H = 231 mm
- Properties
 - Value
 - Modulus of Elasticity
 - 2.05e11 pa
 - Poisson's Ratio
 - 0.3
Results
Figure 3.
| Reference [Target Value]* | SimSolid | |
| Rotation of Cylinder (rad) | 1 | 1 (57.3 degrees) |
*The reference is calculated by hand using a rotation of 1 radian about the cylinder axis.
