Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
Sort the list view in the Files, Jobs, Input, Output, and Running Folder
tabs.
Clicking on a column heading switches the sorting of the list view results by that
column from ascending order to descending order.
Once you have selected a column heading for sorting, a triangle will appear next to the column heading.
An up arrow indicates that the
list is sorted in ascending order. A down arrow
indicates results are sorted in descending order.
Tip: Sorting the list view is applicable in Files, Jobs, Input, Output, and
Running Folder tab.
In this example, we will sort the Job Monitoring list view.
Click the Jobs tab located in the upper left-hand of the
page.
The job monitoring page is displayed with the list of the jobs that is
submitted to a cluster.
Click the Application column heading to sort the list by
job application.
The job listing will be sorted by job application in ascending order.
Clicking the Application column heading again will sort
the list in descending order.
