Altair® Panopticon™
Working with Joined Data Table Editor
The Joined Data Table Editor allows you to join two or more data tables to create a new joined data table. This editor is composed of the following sections:
Join Data Table Editor Sections and Definitions
Section
Back
Exit the Data Table Editor and go to the Data Library page.
2
Data Table Name
Name of the data table. To modify, use the Rename option in the context menu.
3
Data Table Settings
Description of the data table and the auto refresh period (in seconds).
4
Data Table Parameters
Add data table parameters. The inherited data table parameters from the joined data tables are displayed.
5
Search Columns
Allows searching of columns on the Data Preview.
6
Collapse Data Profile Pane
Collapse the Data Profile pane. Click to expand the Data Profile pane.
               7
Data Profile Pane
Displays the following information:
·        Rows of Data Profile (i.e., Value Count, Distinct, Missing)
·        Data Profile Histogram
8
Data Preview
Executes the queries to return and display preview of the joined data table you are creating.
NOTE: The maximum number of rows displayed in the Data Preview is 100.
9
Calculated Columns
Allows you to view and manage the calculated columns. The inherited calculated columns from the joined data tables are also displayed.
10
New Column Options
Allows you to add any of the following columns:
·        Auto Key
·        Calculated
·        Ranking
·        Time Bucket
·        Identity, Sign, Manual, Equal Density, and Equal Distance numeric buckets
·        Text Grouping
11
Group and Sort Columns
When the Column Order is set to Sorted, the columns are grouped by type (Text, Date/Time, then Numeric) and sorted alphabetically.
12
Column Profiling
Perform column profiling either for the Top 1000 Rows or All Rows.
13
Join Settings
Allows you to:
·        View the data tables that are being joined and the join keys.
·        Delete any of the data tables by clicking .
·        Hover your mouse cursor over data tables to view their locations.
14
Join Type
Displays the join type used.
15
Add Data Table
Displays the Add Data Table dialog where you can select data tables to join.
These data tables were created in the Data Table Editor.
16
Join Key
Allows you to select the join keys of the data tables that will be joined.
17
Refresh Preview
Allows you to refresh the data preview.
18
Import to Data Store
Allows you to import the data table to a data store.
19
Save Join Data Table
Saves the join data table definition.
20
Join Types
Allows you to define:
·        Left Outer Join
·        Right Outer Join
·        Full Outer Join
·        Inner Join
·        Cross Join
21
Collapse Data Preview
Collapse the Data Preview pane. Click  to expand the Data Preview pane.
Clicking Transform Settings   displays the Transform Settings pane.
Section
Transform Settings
Allows you to:
·        Pivot or unpivot retrieved data.
·        Transform data to enable time series analysis including interpolation.
·        Run an R or Python script for data transformation.
·        Lists of orders to be reconstructed into an Order Book and conflated for output display.
Clicking Advanced   displays the Advanced Settings pane.
Section
Advanced
Allows you to:
·        Enter custom Error Message that will be displayed when an error occurs while fetching data. Can be parameterized.
·        Retrieve external aggregates
