ANSYS Interface
New Features
- Beam Meshing Tools
 - Stiffener Mesh
- Mesh stiffeners are attached to shell elements. Support for Beam
                                    (188&189) and Rod (Link180).
- Support mesh by proximity using free line but seeding nodes on the closest shells.
 - Inherit orientation from the shell normal.
 - Auto offset beams on top of the shell mesh.
 - You can generate a stiffener on each edge of the source shell elements.
 - The tool auto-generates the property SECTYPE and the associated
                                    section (BEAM card) from the given beam section.
- You can leverage metadata beam section on parts holding free lines. These metadata are automatically created when importing Aveva Marine or OCX CAD formats.
 - Beam Edit Tools
 - The Align tool is used to adjust elements' n1→n2 order.
- Reorder nodes so the X-axis follows the closest global or local system axis in ascending order.
 - The tool supports all types of beam elements.
 - Inflate
 - Convert Beams to Surface and Shell Mesh
- Beam188 with either standard beam section or shell beam section.
 - The tool creates surfaces from the beam section midline.
 - Generate 2D mesh (SHELL181) with thickness assigned.
Enhancements
- Mapping real constants of the COMBIN39p property to a curve entity has been added.
