OptiStruct Interface
Enhancements
- SN Curve Plot Functionality
 - Plot functionality exposed in the Model Browser material view for the MATFAT card defined with single/multiple SN curve definition.
 - Static Failure
 - The MATFAT and FATPARM cards are enhanced to input static failure definition for single/multiple curves in continuation to the SN line.
 - Moved Non-structural Mass and Non-structural Material Damping Cards
 - These cards are migrated from Group to Solver Mass entity.
- NSM1/NSM/NSML1/NSML and NSGE/NSGE1 bulk cards are now mapped to Solver Mass entity.
 - NSMADD bulk data card is now mapped to Solver Mass entity.
 - Multiple Failure Criteria Definition
 - Multiple different failure criteria can be defined on a single MATF bulk card entry.
 - New MATTVE Material Card
 - A new material card MATTVE is added to define temperature-dependent nonlinear viscoelastic material.
 - Model Checker
 - Free 1D element nodes check is now available in the model checker.
 - DENSITY Option in I/O Options
 - A new DENSITY option is added in RTHRESH, THRESH, TOP, RTOP I/O cards.
 - PBUSH and PBSUHT Cards
 - The PBUSH and PBSUHT cards are enhanced to define KMAG and ANGLE continuation lines.
 - SYSSETTING Card
 - The SYSSETTING card is enhanced with a MULTIPLEOUTPUT option to define multiple formats of the same output request.
Resolved Issues
- The JOINTG element type INLINE is no longer imported as INLIORIE.
 - Input files with DRAPE table no longer results in a segmentation error.
 - The PCONT and PSOLID cards in large field format now export correctly.
 - The MPF option is now available in the ERP card.
 - Component organization is no longer lost while importing input with includes created in previous releases.
 - In the Beam Orient tool, orientation in displacement is streamlined.
- System selection and toggle basic/displacement to define orientation vector are removed from the microdialog. A direct option to enter components in the displacement system is available. A vector tool with user system selection to enter orientation vector is always in basic.
 - The OFFT key assigned to elements when assigning orientation in the displacement system no longer has issues.
