A part is a geometric object made up of shell elements. Parts can be grouped together into assemblies and sub-assemblies,
so that you can organize your model hierarchically.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE
studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
Manage the parts and assemblies that make up your model.
Assemblies Overview
An assembly is a list of parts and sub-assemblies that organizes your model hierarchically to reflect the data structure of the modeled product.
Parts Overview
A part is a geometric object made up of shell elements. Parts can be grouped together into assemblies and sub-assemblies, so that you can organize your model hierarchically.
Create Assemblies
Create an assembly and add parts to it in the Model Browser.
Edit Parts and Assemblies
Edit the name, color, visibility, and associated properties of parts and assemblies using the Property Editor. Rename and delete parts and assemblies.
