Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE
studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
Submit Jobs
Use the Run tool to specify the simulation time for a transient run and other setup parameters, as well as submit the actual analysis.
Visualize Results
Use the Show Analysis Results tool to open a results file in HyperMesh CFD Post.
Plot Aero Coefficients
Use the Plot Aero Coefficients tool to generate a 2D graph of the lift, drag, and side forces acting on the body in the wind tunnel.
