Convert Elements and Update FE Geometry
Convert elements that aren't associated with geometry into FE geometry, or update existing FE geometry.
From the Discrete ribbon, click the arrow next to the Mesh Update tool set,
then select either Create or
Update.
Figure 1. - If using the Create tool, select elements not associated to geometry. If updating, select existing FE surfaces or elements.
Click
on the guide bar to
define:
- Remove existing features
- Before creating FE geometry, existing features can be removed.
- (Update only)
- Create at features
- Simple - Fast method of identifying features based solely on the angle between normals of adjacent elements. Based on this, the surface is created.
- Connected - Seeks to avoid any "orphan" or non-closed feature lines. It includes a more rigorous check to combine small areas and avoid creating features that end abruptly or do not connect to any other features while creating surfaces. Example shown below:
Figure 2. - Edge feature angle
- Feature angle based on angle between normals of adjacent element normals. Based on the settings, features are created on the surfaces.
- Vertex feature angle
- Maintain connectivity of the input surfaces to any attached surfaces.
- Allow open features
- Orphan feature edges can be created with this option, as shown in Figure 2 by the Simple example.
- Create at component boundaries
- Feature edge separating the component boundary is created while creating different surfaces.
- Create solids
- Orphan elements forming an enclosed volume are converted into a solid.
- (Create only)
- Create at 1D elements
- Feature edges are created at 1D elements.
- (Create only)
- Create at selection boundaries
- Feature edges are created considering element selection.
- (Update only)
- Click Convert/Update.
