Control which nodes are on the temporary node mark.
Since all nodes not currently referenced in the model are deleted, the temporary node
mark is provided as a holding area to save the nodes you are not currently using.
Those nodes are saved as long as they are in the temporary node mark.
From the Geometry ribbon, click the arrow next to the
Create tool set, then select
Create Points.
From the drop-down menu on the guide bar, select
Mark Free Nodes.
Select the nodes that you want placed in or removed from the temporary node
mark.
If a structural node is selected, it just displays the structural node, but
the ID remains the same. Essentially, it does not create a new node on top of
the structural node. It just shows or marks the structural node.
In the microdialog, choose whether to add or remove the
selected nodes to/from the mark.
Click
When nodes are removed from the temporary node mark, the node is deleted if it
is not attached to a structural element, and is not used by a card in the database.
