Gets the type of encoding used when exporting AMF video files.
Gets the quality used when exporting AMF files using JPEG encoding.
Gets the palette used when exporting AMF files.
Gets the relative size (percent) used when exporting AMF files.
Sets the type of encoding used when exporting AMF video files.
Sets the palette used when exporting AMF files.
Sets the quality used when exporting AMF files using the JPEG encoder.
Sets the relative image size (percent) used when exporting AMF files.
ON THIS PAGE
ON THIS PAGE
