Gets the ID of a layer.
Gets the name of a layer.
Gets a list of the pages that reference this layer.
Gets the visibility of a layer.
Sets the value of a given attribute for a layer.
Sets the name of a layer.
Sets the visibility of a layer.
ON THIS PAGE
ON THIS PAGE
