A generic ASCII reader is now available which allows you to bring custom results directly into HyperView. The AltairASCII format is useful for reading the results of any in-house or propriety codes which are saved in a generic format.
External resources can be registered in preference files, session files, or Templex files. If an external resource is registered in a program session, it is automatically registered in the session
file when the session is saved.
Sets the new master sync block ID and recalculates the master sync table. This command is ignored if the sync table generation
policy is not set to MASTER_BLOCK first.
hwIPage SetMasterSyncBlockID
Sets the new master sync block ID and recalculates the master sync table. This command is ignored if the sync table generation policy is not set to MASTER_BLOCK first.
