Applies the report template settings and draws the report.
Finds the name of the report.
Finds the number of parameters in the report.
Returns the information whether the given parameter is enabled or not.
Returns information about the parameter input.
Gets the resolution list.
Gets the unresolved list.
Loads the resolution file.
This API resolves the TRC (type-request-component) given in the from_string to the to_string.
Saves the resolution file.
Sets the parameter state to true or false.
Sets the parameter of a report.
ON THIS PAGE
ON THIS PAGE
