pltIAnimationCursor GetUseCurveStyle
Determines whether the style of the animation cursor bar (if it has a bar) is the same as the curve.
pltIAnimationCursor_handle GetUseCurveStyle
Tcl Query
This command determines if the style of the animation cursor bar (if it has a bar) is the same as the curve it is on. True is returned if the bar is the same style as the curve, and false is returned if it is not the same style. This command differs from the GetStyle command in that it determines if the style of the cursor bar is the same as the curve, rather than finding the style of the cursor.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetAnimationCursorHandle ach;
ach GetUseCurveStyle;
Success (a true or false value) or an error message is returned.
Keywords
Tcl
Animation Cursor
Query
