pltIAnimationCursor SetUseCurveColor
Determines if the color of the animation cursor is the same as the curve it is on.
pltIAnimationCursor_handle SetUseCurveColor state
Tcl Modify
This command determines if the color of the animation cursor is the same color as the curve it is on.
state
The input for the state variable is a true or false value.
true
If you want the animation cursor to be the same color as the curve it is on.
false
If you do not want the animation cursor to be the same color as the curve it is on.
If the curve is black, the animation cursor will be black either way.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetAnimationCursorHandle ach;
ach SetUseCurveColor true;
Keywords
Tcl
Animation Cursor
Modify
