HM_ExtAPI::CreateSurfaceCylinder()
Creates cylindrical surface object.
bool CreateSurfaceCylinder(
HM_EntityGeometrySurface& new_cylinder,
const HM_Point& center_point,
const HM_Vector& axis,
const HM_Vector& origin_dir,
double radius,
double axis_vfactor
HyperMesh Tcl Modify Command
The function creates the surface object of the type HM_ExtAPI::CYLINDER().
The points on the surface of the cylinder can be calculated parametrically as
S(U, V) = C + R ( p cos U + [n X p] sin U ) + ε n V,
p = P - n (nP) , n = N / | N |
Parameters used by CreateSurfaceCylinder | Cylinder parameters |
center_point | C |
axis | N |
origina_dir | P |
radius | R |
axis_vfactor | ε |
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
- new_cylinder
- [out] - Handle to new surface object.
- center_point
- [in] - Center point of the circular cross section at cylinder base.
- axis
- [in] - Cylinder axis vector.
- origin_dir
- [in] - Vector that defines position of the circle corresponding to U=0 parameter.
- radius
- [in] - Cylinder radius.
- axis_vfactor
- [in] - The factor that defines the rate of the change of the cylinder height corresponding to the changes of V parameter (see Description section above).
None.
