HM_ExtAPI::MeshGetElementCount()
Returns total number of elements in a mesh object.
bool MeshGetElementCount(
const HM_EntityMesh& hmesh,
int & elem_count
HyperMesh Ext API Function
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
- hmesh
- [in] - Handle to mesh object that was returned by previous calls to API functions.
- elem_count
- [out] - Total number of elements in the mesh referenced by mesh object.
None.
