HM_ExtAPI::CreateSurfacePlane()
Creates plane surface object.
bool CreateSurfacePlane(
HM_EntityGeometrySurface& new_plane,
const HM_Point& plane_base,
const HM_Vector& u_axis,
const HM_Vector& v_axis
HyperMesh Ext API Function
The function creates the surface object of the type HM_ExtAPI::PLANE().
The points on the plane surface can be calculated parametrically as
S(U, V) = C + u U + v V
Parameters used by CreateSurfacePlane | Plane parameters |
plane_base | C |
u_axis | u |
v_axis | v |
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
- new_plane
- [out] - Handle to new surface object.
- plane_base
- [in] - The point of the plane corresponding to surface parametric point u=0, v=0.
- u_axis
- [in] - Vector in the plane that defines parametric U axis.
- v_axis
- [in] - Vector in the plane that defines V axis.
None.
