HM_ExtAPI::GeomCoedgesConnect()
Connects co-edges of existing faces into a single edge.
bool GeomCoedgesConnect(
const HM_EntityGeomCoedge& coedge1,
const HM_EntityGeomCoedge& coedge2,
int& orient_code,
bool check_tol,
double equiv_tol
HyperMesh Ext API Function
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
- coedge1
- [in] - Handle to first co-edge object that was returned by previous calls to API function.
- coedge2
- [in] - Handle to second co-edge object that was returned by previous calls to API function.
- orient_code
- [in/out] - Specifies mutual orientation of connected edges. This parameter can have one of following values.
- check_tol
- [in] - Specifies whether co-edges equivalence should be verified before connecting. This parameter can have one of following values.
- equiv_tol
- [in] - Specifies equivalence tolerance. If the number is negative or zero then equivalence tolerance is set automatically. This parameter is ignored if check_tol is false.
None.
