HM_ExtAPI::SurfaceConeGetData()
Returns parameters that define cone surface.
bool SurfaceConeGetData(
const HM_EntityGeometrySurface & surface,
HM_Point& center_point,
HM_Vector& unit_axis,
HM_Vector& ellipse_major_axis,
double& ellipse_ratio,
double& ellipse_phase,
double& ellipse_vparam,
double& ellipse_vfactor,
double& axis_vfactor
HyperMesh Ext API Function
The function expects that the type of surface object is HM_ExtAPI::CONE(). Application should call the function HM_ExtAPI::GeomSurfaceGetType() to verify the type before calling SurfaceConeGetData function.
The points on the surface of the cone can be calculated parametrically as
S(U, V) = C + E0(U) [ 1 + β(V - V0)] + ε n ( V - V0),
where
E0(U) = P cos (U - φ) + α [n X P] sin (U - φ)
are points on the ellipse (shifted to the center point) that defines the cone.
Parameters returned by SurfaceConeGetData | Cone parameters |
center_point | C |
unit_axis | n |
ellipse_major_axis | P |
ellipse_ratio | α |
ellipse_phase | φ |
ellipse_vparam | V0 |
ellipse_vfactor | β |
axis_vfactor | ε |
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
- surface
- [in] - Handle to surface object that was returned by previous calls to API functions.
- center_point
- [out] - Center point of the ellipse that defines the cone.
- unit_axis
- [out] - Unit length axis vector normal to the plane of the ellipse that defines the cone.
- ellipse_major_axis
- [out] - Vector that defines direction of the major axis of the ellipse that defines the cone. The vector has a length equal to major axis half length. This vector is normal to the vector unit_axis.
- ellipse_ratio
- [out] - Ratio between the length of the minor ellipse axis and the major ellipse axis of the ellipse that defines the cone.
- ellipse_phase
- [out] - Cone U parameter value that corresponds to the end of the major axis of constant V parameter ellipse that define the cone.
- ellipse_vparam
- [out] - The value of V parameter that corresponds to the ellipse that defines the cone.
- ellipse_vfactor
- [out] - The factor that defines the rate of the changes of the ellipse size corresponding to the changes of V parameter (see Description above).
- axis_vfactor
- [out] - The factor that defines the rate of the changes of the cone height corresponding to the changes of V parameter (see Description above).
None.
