HMMOD_elementidsetcentroidalresult()
Assigns a centroidal result for an element specified by ID, layer, and index.
void HMMOD_elementidsetcentroidalresult(HM_entityidtype id, int layer, int index, float value);
HyperMesh hmmodlib Function
- id
- The ID of the element.
- layer
- The layer where the centroidal result should be stored.
- index
- The index into the array of centroidal results.
- value
- The value to be assigned to the centroidal result at the specified ID.
None.
