HMMOD_elementsetintegrationpointresult()
Assigns a value to the integration point result of an element specified by element pointer, integration point, layer and index.
void HMMOD_elementsetintegrationpointresult(void * elementptr, int layer, int integrationpoint, int index, float value);
HyperMesh hmmodlib Function
- elementptr
- The pointer to the element.
- layer
- The layer where integration point result should be stored.
- integrationpoint
- The integration point where the result should be stored.
- index
- The index to the array of integration point results.
- value
- The value to be assigned to the integration point of the specified element.
None.
