hide assembly
Hides assemblies in the active model.
hide assembly all
hide assembly displayed
hide assembly <label>
hide assembly <labellist>
hide assembly marked
hide assembly <range>
hide assembly select
Arguments
- all
- Hides all components.
- displayed
- Hides displayed assemblies.
- <label> <labellist>
- Hides assemblies based on labels or lists (wildcards supported). For
example,
"Rigid Barrier", Bump??, back*andhinge, handle. - marked
- Hides marked assemblies.
- <range>
- Hides assemblies based on IDs. For example,
1-3,8,13-20,25?,3*. - select
- Shows/hides entities interactively selected from the modeling window.
Examples
hide assembly allhide assembly "hinge, handle"
