hide measure
Hides measures in the active model.
hide measure all
hide measure displayed
hide measure <label>
hide measure <labellist>
hide measure marked
hide measure <range>
hide measure select
Arguments
- all
- Hides all measures.
- displayed
- Hides displayed measures.
- <label> <labellist>
- Hides measures based on labels or lists (wildcards supported). For
example,
"Measure *", Measure2, MyMeasure*and"Measure 1",Measure2, MyMeasure*. - marked
- Hides marked measures.
- <range>
- Hides measures based on IDs. For example,
1-4,9,13?,3*. - select
- Shows/hides entities interactively selected from the modeling window.
Examples
hide measure 1-2hide measure "Static MinMax Result"
