hide note
Hides notes in the active model.
hide note all
hide note displayed
hide note <label>
hide note <labellist>
hide note marked
hide note <range>
hide note select
Arguments
- all
- Hides all notes.
- displayed
- Hides displayed notes.
- <label> <labellist>
- Hides notes based on labels or lists (wildcards supported). For example,
"Note *", Note2, MyNote*and"Note 1",Note2, MyNote*. - marked
- Hides marked notes.
- <range>
- Hides notes based on IDs. For example,
1-4,9,13?,3*. - select
- Shows/hides entities interactively selected from the modeling window.
Examples
hide note "node 1 Node 77"hide note all
