show assembly
Shows assemblies in the active model.
show assembly all
show assembly displayed
show assembly <label>
show assembly <labellist>
show assembly marked
show assembly <range>
show assembly select
Arguments
all
Show all components.
displayed
Show displayed assemblies.
<label> <labellist>
Show assemblies based on labels or lists (wildcards supported). For example, "Rigid Barrier", Bump??, back* and hinge, handle.
marked
Show marked assemblies.
<range>
Show assemblies based on IDs. For example, 1-3,8,13-20,25?,3*.
select
Shows/hides entities interactively selected from the modeling window.
select only works in HyperWorks.
Examples
Show all assemblies:
show assembly all
Show assemblies by label:
show assembly "hinge, handle"
