show note
Shows notes in the active model.
show note all
show note displayed
show note <label>
show note <labellist>
show note marked
show note <range>
show note select
Arguments
all
Shows all notes.
displayed
Shows displayed notes.
<label> <labellist>
Shows notes based on labels or lists (wildcards supported). For example, "Note *", Note2, MyNote* and "Note 1",Note2, MyNote*.
marked
Shows marked notes.
<range>
Shows notes based on IDs. For example, 1-4,9,13?,3*.
select
Shows/hides entities interactively selected from the modeling window.
select only works in HyperWorks.
Examples
Show note "node 1 Node 77":
show note "node 1 Node 77"
Show all notes:
show note all
