show measure
Shows measures in the active model.
show measure all
show measure displayed
show measure <label>
show measure <labellist>
show measure marked
show measure <range>
show measure select
Arguments
all
Shows all measures.
displayed
Shows displayed measures.
<label> <labellist>
Shows measures based on labels or lists (wildcards supported). For example, "Measure *", Measure2, MyMeasure* and "Measure 1",Measure2, MyMeasure*.
marked
Shows marked measures.
<range>
Shows measures based on IDs. For example, 1-4,9,13?,3*.
select
Shows/hides entities interactively selected from the modeling window.
select only works in HyperWorks.
Examples
Show measures by range:
show measure 1-2
Show measure by label:
show measure "Static MinMax Result"
