tracing display
Define the display options for traced nodes or lines.
tracing display line<name>=<value>
tracing display movewithtracking <true/false>
tracing display thickness <value>
Arguments
- line
 - Select true or false to
                            show or hide the following attributes:
- originalline=<true/false>
 - Displays the original line.
 - surface=<true/false>
 - Displays the constructed surface by the tracing lines.
 - projectedline=<true/false>
 - Displays the projected line.
 - nodetrace=<true/false>
 - Displays the node trace.
 - movewithtracking
 - Select true to move the trace with the entities relative to the tracking system.
 - thickness
 - Select a value between 1-10 to change the line thickness.
tracing display movewithtracking=truetracing display thickness=4
