tracing system
Trace systems during animation.
tracing system add <id>
tracing system color <color value>
tracing system remove
Arguments
add
Select the components to trace.
<id>/<system_id_list>
Define by system ID or list of IDs.
select
Select from the modeling window.
color
Select a system color.
<color>
Display the color picker.
<RGB/label/value>
Enter an RGB value or selecting a color from the list.
remove
Remove the system from being traced.
<id>
Define by system ID.
select
Trace a system during animation:
tracing system add System 5
