tracing modesteps
Select a tracing mode option.
tracing modesteps all
tracing modesteps fromfirst
tracing modesteps id
tracing modesteps last <steps>
tracing modesteps select <value>
Arguments
- all
- All steps of the selected entities are traced.
- fromfirst
- The selected entities are traced starting at the first step to the current step as the model is animated. A line is drawn to illustrate the traced entities. The traced path is erased when the animation starts over.
- id
- The entity ID.
- last
- The traced path is restricted to the last user-specified time steps
before the current step. This gives the appearance that the path is
following the selected entities. The number of time steps specified will
be applied to all entities displayed using this option. HyperView accepts time steps 1-99.
- <steps>
- The number of steps.
- select
- The selected entities are traced for the selected simulation steps.
tracing modesteps alltracing modesteps 4
