plt3DIWaterfall GetColor
Gets the color of the waterfall.
plt3DIWaterfall_handle GetColor
Tcl Query
Returns a color identifier string. The string returned will be either a color name, if the RGB values of the color match a name, an index, if the value matches one of the standard palette of colors, or a set of three RGB values.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetWaterfallHandle myWaterfallName 1
myWaterfallName GetColorErrors
None.
