plt3DIWaterfall SetGenerateCurves
Sets whether the waterfall is visible.
plt3DIWaterfall_handle SetGenerateCurves enabled
Tcl Query
Waterfalls can be created in two ways: either by adding individual curves (slices), one at a time, or by defining matrices mathematically that are used to generate the constituent curves automatically.
- enabled
- Highlighted, true or false.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetWaterfallHandle myWaterfallName
myWaterfallName SetGenerateCurves true
myClientName DrawErrors
Success (0) or an error code.
