plt3DIWaterfall GetSliceHandle
Gets the handle of a particular slice of the waterfall.
plt3DIWaterfall_handle GetSliceHandle iSlice
Tcl Query
Waterfall slices belong to the same class of objects as curves and share the same methods.
- iSlice
- The name of the new handle.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetWaterfallHandle myWaterfallName 1
myWaterfallName GetSliceHandle mySliceName 1Errors
None.
