plt3DIWaterfall GetNumberOfSlices
Gets the current number of slices in the waterfall.
plt3DIWaterfall_handle GetNumberOfSlices
Tcl Query
A waterfall can contain any number of curves. Unlike in the case of a curve group, the slices are assumed to be related curves and to share an orientation or direction.Returns the number of curves (an integer).
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetWaterfallHandle myWaterfallName 1
myWaterfallName GetNumberOfSlicesErrors
Returns an empty string if the value is not defined.
