pltICurveComplex Bridge
Applies a bridge edit to the curve.
pltICurveComplex_handle Bridge from_val, to_val, orientation, interpolate
Tcl Modify
This method only applies the edit. Call the Recalculate method on the parent plot object to update the data.
from_val
The minimum value of the range to be bridged.
to_val
The maximum value of the range to be bridged.
orientation
The orientation of the edit.
horizontal
vertical
interpolate
Indicates whether to create new data points at from_val and to_val (using linear interpolation) if they are not already there. Options include true or false.
Note: This method only applies the edit. Call the Recalculate() method on the parent plot object to update the data.
Returns success or an error code.
