pltICurveComplex RemoveLastEdit
Removes the most recently applied edit from the curve.
pltICurveComplex_handle RemoveLastEdit
Tcl Modify
This method only removes the edit. Call the Recalculate method on the parent plot object to update the data.
Returns success or an error code.
