pltIEdit GetExpression
Gets the replacement expression of the edit.
pltIEdit_handle GetExpression
Tcl Query
This method is only valid for expression edits.
Returns the replacement expression of the edit.
None.
Gets the minimum value of the edited range.
Gets the interpolation state of the edit.
Gets the name of the edit.
Gets the orientation of the edit.
Gets the maximum value of the edited range.
Gets the type of the edit.
Tcl Query
None.
