pltIEdit GetType
Gets the type of the edit.
pltIEdit_handle GetType
Tcl Query
- cut
- trim
- hide
- bridge
- expression
None.
Gets the replacement expression of the edit.
Gets the minimum value of the edited range.
Gets the interpolation state of the edit.
Gets the name of the edit.
Gets the orientation of the edit.
Gets the maximum value of the edited range.
ON THIS PAGE
Tcl Query
None.
ON THIS PAGE
