pltINote GetCoordinateYValue
Gets the y coordinate value when the note’s attachment type is “Coordinates”.
pltINote_handle GetCoordinateYValue
Tcl Query
Returns the y coordinate value when the note’s attachment type is “Coordinates”, that is, the note is attached to particular coordinates in the window.
This method is only valid for "curve" notes.
None.
